Lost ignition timing marks (wont start)
Richie
Post by Richie » Tue Jan 14, 2014 6:56 pm
Just done the head gasket on the G16A engine and like a complete noob I didn't mark the ignition timing when I unbolted the dizzy housing from the block. Im guessing when I put it back on its now on the wrong spline and put the ignition timing out.
Whats the easiest way to regain this as it now wont start. Thx :)
Re: Lost ignition timing marks (wont start)
Post by Jordi » Tue Jan 14, 2014 7:01 pm
Take the dizzy out and set the engine to TDC. Put the dizzy back in lined up just before No. 1 cylinder and should be somewhere near to make it try and fire. Should be able to adjust the dizzy on its adjuster to get it right.
Post by twiss » Tue Jan 14, 2014 7:11 pm
Yeah as Jordi says its pretty easy... imperative to be at TDC on cylinder one though!
Post by Jordi » Tue Jan 14, 2014 7:17 pm
Easiest way to find TDC is to use a piece of dowl or long screw driver in cylinder one and turn the engine over by hand till the dowl stops being pushed out
Post by Darrell » Tue Jan 14, 2014 7:30 pm
And make sure the cylinder is on the compression stroke !! ;)
vit dizzy install.jpg (376.14 KiB) Viewed 10522 times
Rhinoman
Post by Rhinoman » Tue Jan 14, 2014 9:33 pm
I usually set it to TDC at the crank and then look through the oil filler cap to see if the valves are open, if they are its on TDC at no1.
Rhinoman
Post by Rhinoman » Tue Jan 14, 2014 9:34 pm
Jordi wrote:Easiest way to find TDC is to use a piece of dowl or long screw driver in cylinder one and turn the engine over by hand till the dowl stops being pushed out
That could be 1 or 4 as they both come up at the same time.
Richie
Post by Richie » Tue Jan 14, 2014 9:37 pm
thx guys I wil do it tomorrow morning and repot back :)
Post by twiss » Wed Jan 15, 2014 12:18 am
hold your thumb over the no 1 spark plug hole... when its on the compression stroke, it will push air out past your thumb :)
Richie
Post by Richie » Wed Jan 15, 2014 5:31 pm
took 15 mins to do. Fired straight up, thx again guys :)
