2.0l V6 gearbox?
2.0l V6 gearbox?
Which gear box is required for a 2.0 V6 H20 engine?
Re: 2.0l V6 gearbox?
Probably the vit box, think the H series have a different bell housing pattern to the G an J series.
Personally I wouldn't bother with the h20. The j20,h25 or h27 are the better options.
If you're after a V6 Engine and box I know someone with one that he's breaking
engine's still in it.
It's just an idea. Ideally Id like to find a complete vitara so I have all the bits.
Just something different to go into my KJA.
If you mean whole loom, ancillaries, dash clocks etc I'm sure you can have them he only wanted the Vitara for the Axles, seats & headlining.
hmmmmm h20 v6... not much better than the I4 2.0 but with an extra 2 cylinders and (probably) 8 valves to go wrong?
twiss wrote:hmmmmm h20 v6... not much better than the I4 2.0 but with an extra 2 cylinders and (probably) 8 valves to go wrong?
As long as its well maintained there's no issues, it's still just an engine.
A K series rover engine is just an engine but you wouldn't use one of those
Book marked!
That's ties in with this https://www.youtube.com/watch?v=X9h-e0E ... ata_player not much details in the clip but the same build.
