Page 1 of 2
sammy sump swap advice
Posted: Sat Jan 18, 2014 5:17 pm
by mk1joe
helloo:)
im looking at putting my 1.3 samurai sump on my 1.68v soon. I think I asked about this quite a while ago and someone said that to do this the pickup needs to be modified. can anyone expand on this? I assume this means the pickup from the 1.6 needs modifying, but if I used the pickup from the 1.3 would this eliminate need to modify? if not how does the pickup need to be altered?
Thankyou very much guys.
Joe
Re: sammy sump swap advice
Posted: Sat Jan 18, 2014 5:21 pm
You want to use as much of the 413 pipe as possible so it fits in the sump properly.
The problems are that the top end that goes into the oil pump is bigger on the 1600, and that the bracket mounts onto a different place
I did mine by cutting the end off a 1.6 one and welding it to a 1.3 pipe... then chopping off the 1.6 bracket and welding it to the 1.3 pipe
Posted: Sat Jan 18, 2014 5:22 pm
It was quite a while ago though... so I don't have any pics... sorry!
Posted: Sat Jan 18, 2014 5:34 pm
by mk1joe
interesting:) thanks for giving me some insight on it mate, know I know what I will be dealing with. I will try and get it all apart tomorrow and maby take some pictures.
Thanks!
Posted: Sat Jan 18, 2014 5:53 pm
by trotter
have a look through dan_2k's build thread for pics of modding pickup pipe
Posted: Sat Jan 18, 2014 6:03 pm
by trotter
Posted: Sat Jan 18, 2014 6:27 pm
by mk1joe
Thankyo very much!
Posted: Sat Jan 18, 2014 6:30 pm
by trotter
no worries hope that helps/gives you a idea what to aim for
Posted: Sat Jan 18, 2014 6:58 pm
by mk1joe
Yep, seems a bit Fidely thought to get it right. Don't suppose anyone has a pre-modified one kicking about that they want to sell?
Posted: Sun Jan 19, 2014 11:27 am
by mk1joe
ok! next problem...
I have both oil pickups here at home, but the car and engine are elsewhere.
nevermind! im just going to go for it. il give an update later weather it has worked or not;)
Thanks again:)
