g16a ignition coil problem?
Hi guys, after 10 months of trying to resolve a running problem with the suzuki im starting to think it might be the ignition coil. After 15 mins or so of running fine it then starts to splutter and die. Im wondering if the coil is over heating so wanted to try a new one. But my parts suppliers cant identify which one it needs and im not sure if it has a 1.6 vitara one on atm
Re: g16a ignition coil problem?
you've tried a new fuel filter i presume? you want to measure the resistance of the ignition coil between the primary and secondary terminals and compare against service data when the coil is cold and hot... this should tell you if its dying or not
As for replacement... I got myself an MSD blaster coil to replace my samurai one and its perfect!!!
http://www.ebay.co.uk/itm/MSD-Blaster-2 ... 3a8a14d489
Click Here for Ebay Listing
Been trying to upload a pic of my coil but it looks the same as the ebay one. Looks just what I need thx. Did u have to put anything else on or only the coil? Thx
If it looks the same as that it will probably be correct... just make sure your one doesn't have a ballast resistor as well... but I dont think it will having a vitty coil
i would still use a multimeter and test your coil though... i will post the proceedure in a sec
here you go
- coilservice.png (22.67 KiB) Viewed 5281 times
