transfer box
Posted: Tue Feb 04, 2014 3:19 am
by windsor
So when offroading this weekend my transfer box kept jumping out of 4l when getting the revs up in the muddy stuff
4h works perfectly all the time
and if i revere more than a few feet and set off ti go forward again it will jump out
Driveing around normally on sillypy stuff in 4l its fine any1 have any clue as to what could be happening
Re: transfer box
Posted: Tue Feb 04, 2014 6:22 am
Transfer box mounts might be bent. Some times it cause the lever to knock against the hole in the transmission tunnel.
Re: transfer box
Posted: Tue Feb 04, 2014 7:00 am
by windsor
Cheers ill have a look inabit
take it the easy fix is make a bigger hole
Re: transfer box
Posted: Tue Feb 04, 2014 8:10 am
If it is bent mounts your better off straightening them.
Re: transfer box
Posted: Tue Feb 04, 2014 9:17 am
by NylonAdmiral
I would echo exactly what Jordi said, the only thing I'd add is that I've found this happen to me before and it was as simple as the gaiter was bunching up in front of the transfer box's gearstick. This meant that the gaiter was very slightly pushing back on the stick when it was all the way forward (as in 4L). I just fiddled with the gaiter a bit to try and reduce the problem and it was fine.
Re: transfer box
Posted: Tue Feb 04, 2014 9:32 am
having the gator on backwards can cause this and is the most common cause.
it could also be the that the lever bush is worn.
Re: transfer box
Posted: Tue Feb 04, 2014 10:13 am
by ROBBIE
I've done what Scott said and put the gator on round the wrong way and it kept jumping out
Re: transfer box
Posted: Tue Feb 04, 2014 1:48 pm
I think everyone's put their gaiter on the wrong way round before!!!
Re: transfer box
Posted: Tue Feb 04, 2014 2:20 pm
by windsor
Kwl thanks give me pleanty to go at
