Look at it and the axle saddles have gone like this they where alright when I chaned the springs about 2 mounths ago
So I will take of axle next Sunday as I have a week of college and I can walk to work will inbestigate the situation and go from there migtbend out put a layer of weld on it and go from there if not cut off and make a set of new saddles or even better use the spare Spanish rear axle casing as if has good spoa saddles as I hae just looked
Why had the axle saddles gone like this
- dazerede
- image.jpg (1.31 MiB) Viewed 3300 times
4” calmini lift kit
4” calmini lift kit
Re: Why had the axle saddles gone like this
Is it actually bent or has the axle just turned slightly?
I would guess the u bolts weren't tight enough and it's caused slight axle wrap.
Is that the front or back?
- dazerede
It the rear axle
I will tighten the u bolts and go from there I have a spare axle casing so I might swap it over
4” calmini lift kit
4” calmini lift kit
I would guess that the bolts weren't tightened enough or were over tightened and stretched a little.
