Samurai 413 LWB repairs underway at last.
Posted: Thu Feb 13, 2014 3:41 pm
Well after quite a spell (due to illness and lack of cash) my 1991 LWB is finally receiving some long needed attention. Ok, so apart from considerable welding and body work repairs, (going to tackle this once she is driveable) this is the list of faults found so far:
Head gasket- knackered (the oil looked more like anti-freeze) when dropped. So in the process of stripping down and then off for a skim.
Valves- we'll see once the head is off (fingers crossed)
Timing belt- shot
Choke- faulty- always shut
Thermostat- stuck open
Rear Diff- (there's a bucket of spanners in there somewhere) a re-build needed
Battery- dead- now replaced
Various hoses, filters etc. shot or wrong type fitted by previous owner/s
Steering- seems Ok
Brakes -working -ish. Not been over 20mph in her so far (and that was pushing it-given the rear diff) so not much chance of a decent test, visually Ok
Clutch- seems Ok
Gearbox and transfer box-Ok
Water pump, fuel pump and filters-Ok
Electrics- mostly Ok
Rear wash/wipe (bag split)
Seats-rough
Seat belts- Ok
Heater not tested as not been able to get her warm yet.
Drivers window winder mechanism -knackered, passenger side Ok
Door cards-just about Ok but will probably re-do at some point
Rear seats, not fitted at present but Ok
GRP load bay body- a few dents and cracks but Ok-fixable
Fixing points for above- rusty and need work
Removable cab roof-Ok
Rear door and glass-Ok
Wheels and Camac tyres all good
Exhaust seems Ok but hard to hear over the diff noise!
Chassis- looks Ok
Front inner wings-rough
Front floor pan- Ok
Bonnet and outer wings, grill, bull bar all Ok
Windscreen Ok
Wipers Ok (new blades needed)
Sills- well there may have been some once, now mostly the plastic trims are all that's left
Rear floor pan- a few mouse and rat holes here and there
Rear wheel arches- much as the front-lots of daylight.
Bought on ebay unseen last summer so plenty to be getting on with as expected. I will try to post some pics as we go along.
Timing belt- shot
Steering- seems Ok
Clutch- seems Ok
Seats-rough
Seat belts- Ok
Chassis- looks Ok
Front floor pan- Ok
Windscreen Ok
