What To Do ?
The Bird Man
What To Do ?
Post by The Bird Man » Mon Feb 17, 2014 4:07 pm
Alright chaps, me again :roll: Right, I've got a 410 engine with a Sammy body, dash and wiring loom, I'm in the process of putting everything back together and it's only just twigged while connecting the alternator up that it's a different plug. Question is how many other parts of the loom are different compared to the 410 one ? I've got a 410 loom but that's still attached on the other body (another project). What's the best thing to do without causing too much of an headache ?
mk1joe
Re: What To Do ?
Post by mk1joe » Tue Feb 18, 2014 9:24 pm
if its only a 410 engine that's going in and everything else is samurai than I would stick with the samurai loom. I had the problem with the alternator plug when I put my 1.6 in my Sammy. basically as long as you know which wire goes where you don't need a plug, you can just put it together with spade connector's.
I cant remember which wires go where, only that one goes back to the battery, and when connected right one will illuminate the battery light on the dash.
Hope that helps!
joe
Re: What To Do ?
Post by ScottieJ » Wed Feb 19, 2014 11:50 am
This thread should help, just backwards.
http://forum.suzukiclubuk.co.uk/vi ... =11&t=2100
As I advised on facebook though, would also be worth swapping over to the 413 coil and dizzy to get rid of the old points ignition.
