number2/3
stevepsj413
number2/3
Post by stevepsj413 » Wed Feb 19, 2014 10:56 am
Found a hardtop samurai the other month no engine or gearbox in it, I managed to do a deal with the owner and now its mine, well pleased ive wanted a hardtop for a while. I did originally have a soft top one i was going to restore but its had a lot of parts robbed off it to keep my other one on the road and it was suffering badly from tin worm, it did have a good engine and box in it though so I think ive got enough parts to build the hardtop one back up. Only problem is space, or lack of it so I have to get rid of the soft top before the new one arrives. Got my socket set out yesterday and set about it.
This is as far as i got, all stripped just the axles to take off. Just waiting for the new one to turn up now, going to try make it look brand new, fully standard. The new ones quite solid, apart from where its been towed with no engine and the prop from the t/box has spun round like a propeller and ripped the floor up, looks like i'd best get me welder out!
The hardtop
The hardtop
R.I.P Rust In Pieces
Re: number2/3
Post by ScottieJ » Wed Feb 19, 2014 11:41 am
Looks like a good project!
get yourself a set of spot weld drill bits and it won't take too long to remove the transmission tunnel from the swb to fit into the tin top :thumbup:
Ladaman
Re: number2/3
Post by Ladaman » Wed Feb 19, 2014 5:44 pm
The last picture is a belter.
I bet it made someone jump when that happened! :shock:
Re: number2/3
Post by Edweird » Wed Feb 19, 2014 11:42 pm
Ladaman wrote:The last picture is a belter.
I was just thinking the same. Looks like a flywheel explosion. Is there a pair of sawn off legs in the footwell with it as well?
Re: number2/3
Post by twiss » Thu Feb 20, 2014 12:41 am
Bloody hell, I had a mid prop let go once... I should be glad it only took out the wiring loom and the transfer box
Re: number2/3
Post by Edweird » Thu Feb 20, 2014 2:34 am
twiss wrote:Bloody hell, I had a mid prop let go once... I should be glad it only took out the wiring loom and the transfer box
Oh, yeah, of course, the flywheel's too far forward. Derp.
stevepsj413
Re: number2/3
Post by stevepsj413 » Thu Mar 06, 2014 6:58 pm
Started to do a bit of work on my project over the last few days, Ive managed to remove what was left of the tunnel, it came with a donor floor that had been cut out of another sj. There was plenty of floor left, tricky bit was getting it to match the hole I'd just cut out of the anus, think I did an ok job, once its had a bit of weld on it I should be able to get the gaps to close up with a bfh! The man who I got the anus off also gave me some rear wings of a lwb to use for repair panels on mine. Just picked up my new welder so off for gas tomorrow and then see how it goes from there.
Got both sides of these, a lot easier than trying to fabricate some
fits like a glove, almost
stevepsj413
Re: number2/3
Post by stevepsj413 » Sat Jul 19, 2014 3:35 pm
Its been a while since I updated this so here's a few photos of some of the work I've done so far, if you don't like looking at photos of welding then this probably isn't for you! It took me about a month of afternoons and weekends to get to this, Ive done some other work to the engine and running gear but ill add those photos later.
A fresh coat of black paint before i fit the engine
Passenger side wasn't half as bad, didn't need any repairs, the box just went straight in
all in place ready for the plastic arch
now i need to make something to fit the plastic arch to
cut to shape and painted with red oxide
a view from inside
a view from inside
rear repair panel welded in
some of the rot cut out, time to do some metalwork
100mm box section replacing standard cills
repaired the inner skin
cill, inner and outer wing all rotten
i knew it needed new cills, didn't think it was this bad though!
repair panel cut from donor anus
hole in the rear passenger footwell
seat bracket back in position
hole under drivers seat bracket repaired
tunnel welded in and drivers side footwell repaired
Re: number2/3
Post by Darrell » Sat Jul 19, 2014 6:08 pm
Well done, I'd have took one look and said sod it with all that rust, but you've managed it. :thumbup:
RickUK
Re: number2/3
Post by RickUK » Sat Jul 19, 2014 6:23 pm
That is a real quality job that you are doing,must admit i wish i had some welding skills :weld: but i do enjoy reading these build threads :thumbup:
Deceased.
Current wheels.
