Starter Motor Problem
The Bird Man
Post by The Bird Man » Wed Feb 19, 2014 7:20 pm
Evening chaps, tried firing up the SJ today but the starter motor doesn't seem to engage with the fly wheel, ( Well not every time, it's hit and miss, more often than not it doesn't engage) The bendix spins and returns okay as I bench tested it but when I put it back on the engine it doesn't seem to catch. Any ideas to why this is ?
timwilks13
SCUK Website Padawan
Re: Starter Motor Problem
Post by timwilks13 » Wed Feb 19, 2014 7:26 pm
What do the teeth on the fly wheel look like through the inspection hole on the bell housing?
The Bird Man
Post by The Bird Man » Wed Feb 19, 2014 7:28 pm
Forgot to mention, the flywheel teeth all look good. No sign of ware, same on the bendix :)
timwilks13
Post by timwilks13 » Wed Feb 19, 2014 7:37 pm
Does it sound like it's grinding as though it's flicking out but not catching or not flicking out? Can you hear the solenoid click?
The Bird Man
Post by The Bird Man » Wed Feb 19, 2014 7:45 pm
The bendix is flicking out but not grinding on the flywheel, and yeah can hear the solenoid click :)
Post by ScottieJ » Wed Feb 19, 2014 7:50 pm
Are you using the 410 starter?
The Bird Man
Post by The Bird Man » Wed Feb 19, 2014 7:52 pm
Yeah, tried to swap it with the 1.3 starter but realized it doesn't fit.
ferris
Post by ferris » Wed Feb 19, 2014 8:34 pm
Last time I had that problem it turned out to be a dodgy battery terminal. If I turned they key with the bonnet open you could see the terminal sparking when the starter kicked in.
timwilks13
Post by timwilks13 » Wed Feb 19, 2014 10:18 pm
And mine used to do it if the battery didn't have enough juice.
Post by twiss » Thu Feb 20, 2014 12:32 am
Try and turn the drive gear in the starter by hand... it should only turn one way (does on all the ones I have anyway).
if not i believe its broken!
