Evening guys, wiring question.
So I've ripped out the Sj loom from my suzuki, now I just have the vitara 16v engine loom and that's it.
Is it possible, and if so how do I do it. Can I wore the wire which is coming from the afm (or coil can't remeber which) to the rpm gauge in the Sj clocks? Do I have to power the clocks or not? And the same with coolant temp?
I've done it before, but the Sj loom was also used, so didn't know if that powered it?
Will they work purely with the signal from those sensors, or do I have to do something else?!
Many thanks
Mike
Rhinoman !! I need your asistance !!
- mike harris
- SCUK is my life
Re: Rhinoman !! I need your asistance !!
You need to wire from the coil through a noise suppressor to the tach. You need 12V to the instrument panel.
- mike harris
- SCUK is my life
So the same as it was, just need a 12v feed. Don't suppose you have a diagram?
Or can tell me where the feed is to the dash has to go?
Thanks
Mike
Thanks
Mike
