Hi guys,
Anyone got any info on how to change the headlight bulbs? I'm hoping to replace them for some LED ones so the light is white (better for spotting eye shine whilst hunting). The only issue is i can't remove the old ones to check what bulbs they are!
Any idea on how to remove them? Maybe a quick video or a few pics would help me...!
Thanks in advance
Changing the head light bulbs... basics???
- Phillips321
Re: Changing the head light bulbs... basics???
On the old 410s they have sealed unit headlights and you can't take the bulbs out.... you will have to fit some aftermarket ones, or samurai headlights... sorry!
- Phillips321
- Winching along now
My Jap '87 had original headlights (I might be wrong?) with removable bulb unit , here's some pics if it helps
That looks like a separate bulb in there
Yep Robbie is right thats just a twist off one.... my bad I think it was the 83-84 that had the sealed unit.
Just make sure you get the right bulb fitting as it will probably be a P45T
