Hot battery
Hot battery
Post by ROBBIE » Fri Jul 27, 2018 8:31 pm
So should a battery get hot whilst trying to crank the engine?
Re: Hot battery
Post by andyrew » Sat Jul 28, 2018 5:59 pm
Warm possibly. Hot sounds like it's shagged.
Has it been left to go flat? Has it been put on charge a lot?
Re: Hot battery
Post by ROBBIE » Sat Jul 28, 2018 8:33 pm
Would say warm to hot, is supposed to be a new battery that has never been charged.
Really thinking about it now, could of beenhow much I used it, did spend a lot of time trying to get it started :lol:
Re: Hot battery
Post by andyrew » Sat Jul 28, 2018 11:02 pm
Check the either end of the battery. See if the ends are bulged out. If they are then the battery has sulphated and will struggle holding a charge or provided enough amps on cranking.
If you was trying for a long time to get it started I'd guess a hot battery could be expected.
Re: Hot battery
Post by mike harris » Sun Jul 29, 2018 10:18 am
Check the charge rate to make sure it's not over charging man.
