O2 sensor wires
colham
O2 sensor wires
Post by colham » Wed Feb 06, 2019 3:09 pm
Hello all. - I need help in identifying the harness wires to the o2 sendor on my 97 vitara jlx
colham
Fuel odour
Post by colham » Wed Feb 06, 2019 3:15 pm
Also, - there is a strong odor of fuel at the back of my car. - I have changed the fuel tank, the h oses, and the tank cover. - there are no leaks but the odour remains strong and this only happens when the engine is off. - any ideas??
Re: O2 sensor wires
Post by Anton » Mon Feb 25, 2019 4:20 pm
When you changed the hoses, did you also check the tank vent hose?
colham
Re: O2 sensor wires
Post by colham » Mon Feb 25, 2019 4:33 pm
Anton, bcause the car was poorly converted from a carburettor to a EFI engine there is no EVAP canister so the vent host from the tank goes nowhere but this odor problem only recently started after months of driving, I suspect the o2 sensor may be sending a wrong signal to the ECU so I need to know the colour of the harness wires that connect to the o2. - let me say also that I am having a hard start problem hot or cold, but once its started it runs flawlessly.
Re: O2 sensor wires
Post by Anton » Mon Feb 25, 2019 4:50 pm
EFI stuff is above my paygrade, but ScottieJ or Darrel might know.
colham
Re: O2 sensor wires
Post by colham » Mon Feb 25, 2019 5:02 pm
Thanks anyway for your interest in helping. Hopefully those guys may see this SOS and sail to the rescue. - cheers.
