Hey guys. My mate, Mad Lada Tony, is upgrading from a Lada Niva to a 410.
There's a weird thing on his coil, it gets very hot - bypassing it doesn't seem to make any difference, but does anyone know what it is?
A ballast resistor? A noise suppressor? Anyone know what it actually is???
Coil thingy...
Coil thingy...
- timwilks13
- SCUK Website Padawan
Re: Coil thingy...
Its a ballast resistor, has he definitely got the right one for a 410, the 413 ones are a different value I believe. Also they only work with a coil design for one, so if the coil has been replaced it may not need it, or may need a different one.
Re: Coil thingy...
Roger that. I'm told it works without it, and there's a good chance that the coil is actually from a Lada Niva. He's got a few of those, and he did say something about pulling the coil out and trying another one.
Thanks for the info, I'll tell him not to worry about it.
Re: Coil thingy...
The ballast resistor is needed, they do get hot, That’s why they have a ceramic coating.
It is needed to drop the voltage to 9v for the coil as it’s a 9v coil. it’s only bypassed briefly during starting if wired correctly.
Bypassing it permanently will cook the coil, points and condenser.
You MUST run a 9v coil with ballast resistor when running a dizzy with points.
Re: Coil thingy...
Even if the coil has been changed?
I don't know anything about points, but he did confirm that this machine has points.
- timwilks13
Re: Coil thingy...
I would just swap the lot to a 413 dizzy and coil, do away with the points all together.
Re: Coil thingy...
Sounds like a good plan, Tim. Do you know if a 413 dizzy is swappable? Google isn't being much help at the moment...
Re: Coil thingy...
If the coil has been changed it needs to have been changed to a 9v unit and use the ballast resistor. a 12v coil will fry points.
You can swap in the 413 dizzy and a 413 coil, problem is theres no suitable point to fit a vacuum port on the carb for the vacuum advance.
