On with wiring SJ .
Just about got all lights done and working except for Revers Lights,
Can anyone tell me where Switch is, or is supposed to be. Looked all over cant find it.
Thanks
Revers Light Switch
- donkeychomp
Re: Revers Light Switch
Couldnt see it Mate, from underneath but just found this https://forums.off-road.com/suzuki-geo- ... rking.html so hopefully should find it when I look tomorrow.
If I remember rightly, it is on top of the gearbox. If you look from under the bonnet, just behind the bell housing is a 'thing' with a couple of wires coming out of it. There will be a joining block just above were the cables come off the wiring loom held onto the bulkhead.
Thanks Mate. Will look today.lundigee wrote: ↑Thu Oct 29, 2020 11:19 pmIf I remember rightly, it is on top of the gearbox. If you look from under the bonnet, just behind the bell housing is a 'thing' with a couple of wires coming out of it. There will be a joining block just above were the cables come off the wiring loom held onto the bulkhead.
Found it , ran 2 wires up to plug and works perfect.
Thanks Everyone.
Thanks Everyone.
