Battery
archiepie
Battery
Post by archiepie » Thu May 14, 2009 5:23 pm
What is the correct battery to have in a SJ413 1300? The one in there is a 40/295 and has died after 6 months!!
Henry
Re: Battery
Post by Henry » Thu May 14, 2009 7:43 pm
Get the biggest one you can get in the tray. Be careful not to let it discharge too often, as this can kill them.
If it lasted 6 months, take it back and they should refund it. They normally cut the date when it was sold in the top...
Kirkynut
Re: Battery
Post by Kirkynut » Fri May 29, 2009 3:38 pm
The standard sized battery is fine for an SJ with no winch etc but as mentioned above will die early if left to discharge through lack of use. I've wasted a battery like this over the last year and have invested in a solar charger from Maplin for £12.99 to keep it topped up whilst not in use. This will save my new battery and I plan to use it more regularly.
If you have used the car regularly and the old battery is only 6 months old, ask for a new one in exchange from where you bought it, they all have a guarentee these days.
Kirkynut
