There are a few different types of caliper found on Samurais, and I've come across two sets of these 2-piece Girlings now. They seem to be less common than the other type of Girlings or the Aisin calipers.
The problem that I found is that these 2-piece ones are pretty awkward to buy seal kits or parts for. I tried Brake Int. and Bigg Red, both listed other seal kits for what they thought should fit this caliper, neither fitted. If you use a registration lookup, they almost always list the wrong kit for these calipers.
It turns out that there is a seal kit which fits this caliper, it's for a Dacia Logan (front). If you have these 2-piece Girlings, then this kit from Bigg Red will fit them.
Caliper Seal Kit For Samurais
- NylonAdmiral
- Winching along now
Re: Caliper Seal Kit For Samurais
Good to know!
- NylonAdmiral
Yeah, it's one of those oddities that took a while to figure out so thought I'd share it.
They look the same as the ones I'm referring on the LJ, but not home for a couple of days. If they are I got my kit from brakes int. Will check when home
They are the same calipers as I have on my LJ. I got my kit from Brakes International, part number BCK4857
