Sj Brake Master Cylinder
Posted: Sat May 26, 2018 1:53 pm
by Famerbennie
Hi all think i need to replace the brake master on the trusty sj. The two pipes come out the bottom of the master at the moment. Are there any others i can use ie vitara etc. Many thanks
Re: Sj Brake Master Cylinder
Posted: Tue Jul 31, 2018 5:23 pm
by Famerbennie
Are all sj master cylinders the same?
Posted: Tue Jul 31, 2018 7:59 pm
Whats the actual problem with your existing one?
There are different versions but without looking i can’t remember the specifics.
Thinks its like brake calipers, a jap version and a spanish version.
Posted: Tue Jul 31, 2018 9:34 pm
by andyrew
Servo or non Servo?
Jap or Spanish?
On a sj413 or sami
Aluminium it's jap
Black and rusty steel it's spanish
Posted: Wed Aug 01, 2018 5:56 pm
by Famerbennie
Servo on a 410 santana if that helps.
I think the seals gone inside as pedal goes almost to the floor but if pumped a couple of times it gets better.
Posted: Wed Aug 01, 2018 6:09 pm
Its not low on brake fluid?
No air in the brake lines?
Brake fluid leaks?
Posted: Wed Aug 01, 2018 8:17 pm
by andyrew
Double pumping, I'd expect a sticky caliper with worn out pads (discs maybe on the minimum) or shoes that have worn think.
Does the pedal creep down slowly when you hold the brakes ?
Posted: Wed Aug 01, 2018 8:19 pm
by andyrew
And yes. Spanish masters are fooking expensive!
