- Front axle (250 x 141).jpg (12.04 KiB) Viewed 7804 times
- two wheels (200 x 112).jpg (8.1 KiB) Viewed 7853 times
Two wheels on my wagon but i'm still rollin along !
there's always something missing or over when you finish a job isnt there ?
Update.
Its been decided to abandon the SPOA and go back to spring under axle but with a 2" shackle lift enough for clearance for the tyres giving it just a little height, this was decided for a better road handling and safety, and to keep the costs down without going to new springs (that maybe done at a later date if one gets bent or something)
Now onto the front axle, rear diff reassembled and fitted new bearings in axle done wheels back on and new brake pads done as it has had discs fitted previously, hand brake shoes replaced also.
still needs new 2" extended shockers on all four corners, probably from Jimney bits in Stoke or Llama 4x4
Found some reasonable Corsa seats from the scrapy, just waiting for them to become available. Probably another hundred jobs to do yet and then MOT the truck.
But Work progressing
Dave
