Huw's '89 SJ 410
HuwJones
Huw's '89 SJ 410
Post by HuwJones » Mon Mar 18, 2013 10:17 pm
I thought I’d just start this thread showing what I’ve done and what I will do to my SJ. Here's what I’ve done over the last 2 weekends.
1) Welding a patch on the inner arch on the driver side.
2) Waterproof the back 'hatch' and the roof
3) New wheels and tyres
4) New fuel tank and fuel lines
5) Service engine gearbox, transfer box and differentials.
6) Attach spot lamps to bumper
7) Patch bumper
8) Re-wire spotlights
9) Make battery box and battery securing clamp.
and the To-Do list (next few weeks)
1) Sort out rust on bodywork.
2) Home made bumpers (ones on it are ok for now, but very rotten)
3) Removable aluminium roof and hatch in back.
4) Re-waxoil part of chassis and underneath.
To-do list 'eventually'
1) Completely strip down to chassis and rebuild (sometime in the next 5 years!)
2) Winch (within a year)
3) 1.6 Vitara engine conversion (within a year)
I will upload some photos tomorrow.
Huw
There's three ways of doing things,
1) The Right Way,
2) The Wrong Way
3) My Way.
2 & 3 are usually the same.
Re: Huw's '89 SJ 410
Post by Jordi » Mon Mar 18, 2013 10:24 pm
Looks good. Can't wait for the photos. Good to see you are on top of the oily bits.
I can't believe how short your to do list is. Mine is just depressing.
HuwJones
Post by HuwJones » Mon Mar 18, 2013 10:28 pm
That's the 'short' to do list. There's another one for the little inconvenient things that I can live with for now. Like getting some proper window winders to replace the mole grips that I use to open the windows now and making some sort of roof rack so I can start using my kayak again!
1) The Right Way,
2) The Wrong Way
3) My Way.
Post by Jordi » Mon Mar 18, 2013 10:36 pm
Give mike harris a shout for window winders. I got some off him along with various other bits. Did me a decent deal.
dazerede
Post by dazerede » Mon Mar 18, 2013 10:38 pm
Looks like u have.been busy
Don't forget the pics
4” calmini lift kit :)
Post by Tramp » Mon Mar 18, 2013 10:49 pm
Re window winders, I got some aluminum ones from eBay, stronger than standard :thumbup:
HuwJones
Post by HuwJones » Tue Mar 19, 2013 10:34 pm
Here is some photos as i promised.
The switchbox i made for the Top Spotlamps, Bumper Spotlamps, Interior light and 'Spare' (Eventually for a winch 8-) )
The 'Black One' dwarfed by co-workers Landys. I bought it off the brother of the guy that owns the Disco.
The 'Black One' at the bottom of the access road to Cwmorthin, a local valley that's full of quarries an mines.
Road alloys (front) and the Amazon off roaders i got with the car. I've kept the Amazon wheels for offroading.
Replacing the fuel tank at work. I'm working over a 1860s built pit that's used to service the 'Double Fairlies' of the Ffestiniog Railway (my employers)
At work with the offroading wheels on.
The rotten bits that once held the indicator and dim light on the bumper.
New indicator / dim light mounting bracket. Will be held on with a stainless steel M4 bolt and nut.
Hole in bumper filled, before grinding and painting.
Front lights put on. They where originally off a MK2 Scirocco. I will eventually make a new bumper out of something a bit more robust! There isn't much material left on the mounts! I've patched it up to get it pass the MOT in April!
1) The Right Way,
2) The Wrong Way
3) My Way.
HuwJones
Post by HuwJones » Wed Mar 20, 2013 6:41 pm
For my 1.6 engine swap, would a engine out of any 1.6 Vitara do, or does it have to be a specific range of years?
Thanks
Huw Jones
1) The Right Way,
2) The Wrong Way
3) My Way.
Post by andyrew » Wed Mar 20, 2013 6:49 pm
Ahhh Ffestiniog . Been many a year since I was there. Love a bit of narrow guage.
Sj looks tiny in between the landys
Post by Jordi » Wed Mar 20, 2013 6:59 pm
Easiest is the 1600 8v carburettor engine.
I'm doing the 1600 8v SPi. But i'm converting it to a carburettor (SU HIF44). Easy to do just requires a adaptor or manifold mod. Also requires an electric fuel pump as the standard SPi pump is too high pressure.
I'm led to believe all the wiring for the 8v is almost identical to the SJ wiring.
Hardest, from my point of view is the 16v Mpi, requires wiring, ECUs and al kindsa technical shit.
See http://forum.suzukiclubuk.co.uk/vi ... 13/t,6099/
