GV Headlamp Washers
SteveyM
GV Headlamp Washers
Post by SteveyM » Sun May 22, 2022 9:30 pm
Anyone had problems with their headlamp washers?
Mine haven't worked since I bought the GV last year. My first suspicion was maybe the pump had packed up but I've pulled the switch out the dash and if I run a wire from the power terminal (on the connector/plug) to earth the washers operate so I'm presuming the pump is ok. I'm not great with electrics but would that suggest the switch is at fault or more that I've got a problem with an earth somewhere?
Many thanks in advance.
Steve.
SteveyM
Re: GV Headlamp Washers
Post by SteveyM » Wed May 25, 2022 2:12 pm
Problem sorted, I hadn't realised the headlights needed to be on for the washers to function!
