Break Pads Installation
avivyaku
Post by avivyaku » Thu Oct 31, 2019 1:25 pm
Hello Guys ,
Got a 2016 Suzuki vitara 1.6L and its time for break pad replacement.
When i opened the break caliper i saw a V spring that sitting at the bottom of the caliper.
My question is what the purpose of that spring and how do i place the new break pads? before the spring or after?
Thanks ,
Aviv.
timwilks13
SCUK Website Padawan
Re: Break Pads Installation
Post by timwilks13 » Thu Oct 31, 2019 5:53 pm
Have you got a photo of said spring? Never done pads on a GV that late, but the general rule is put things back together the opposite way they came apart. At what point did you take the spring out?
Post by ROBBIE » Thu Oct 31, 2019 7:47 pm
Open up the other side and have a look in there
Post by Anton » Fri Nov 01, 2019 1:55 pm
Yes, and when you pull the other side apart, take loads of photos so you know how to put it back together. Post the photos here and maybe we can help - but I don't think any of us have dealt with a Vitara of this generation.
Brakes international thinks your pads look like this:
Is your pad anything like that?
avivyaku
Post by avivyaku » Mon Nov 04, 2019 6:28 pm
Yeah exactly like this.
I realised that those springs are for seperating the pads from the rotor but i dont know from where the knocking sound is coming all time when im breaking in reverse and slow speed...
Post by Anton » Mon Nov 04, 2019 11:37 pm
Get someone to listen near each wheel as you reverse/brake and find out which wheel the noise is coming from. Don't assume that it's brakes, it could be a faulty wheel bearing (braking forces change the load on bearings), although it does sound like something is loose inside a brake drum or brake caliper to me.
If you have rear drums, then it could also be the handbrake automatic adjustment making that noise, if it's not working correctly.
