Wanted evap purge valve for 1995 Vitara G16B
sammonsqi
Post by sammonsqi » Sun Jun 07, 2020 10:20 pm
I need to replace my broken evap purge solenoid valve. Can't find one online - mine mounts at the front of the EFI and has one outlet going upward, and the other going forward. I wonder if one from a later model, i.e. 2001 Grand Vitara might do the same job?
Larry
Re: Wanted evap purge valve for 1995 Vitara G16B
Post by Larry » Thu Jun 11, 2020 5:36 pm
I would think that this is a very generic part, is there a part number on the body of the solenoid? If you try searching for that rather than a Vitara specific one you may find there are plenty about that are used on other models too!
