lifting a vit...
lifting a vit...
Post by donkeychomp » Mon Apr 23, 2012 10:41 pm
Just wondering if anyone knows the easiest and (lol) cheapest way to lift a Vitara?
Would bigger shocks be the way to go?
I'd prefer not to do a body lift.
Cheers, Alex.
Re: lifting a vit...
Post by turbo-tom » Mon Apr 23, 2012 10:44 pm
bigger shocks, bigger springs maybe ?, spring spaces? bigger wheels i dont know to be fare :lol:
Post by donkeychomp » Mon Apr 23, 2012 10:49 pm
Trying to find bigger wheels/tyres now but some ebay prices are bonkers! :shock:
Post by dan_2k_uk » Tue Apr 24, 2012 8:47 am
Spring and shock spacers/drop mounts will probably be quickest and easy.
Dont know about pricing as I've never shopped for any.
Cant imagine they would cost anywhere near that of a body lift but may need extended brake lines and diff dropping on the front.
Maybe there are some longer cheap altenative shocks?
Dan
vitara_mad
Post by vitara_mad » Tue Apr 24, 2012 9:53 am
depending on how much lift you want there is lots of options to lift a vit
the more you lift the more parts you need to change & more money you need to spend
if going over 2" you will need diff drop brackets for front & hiem spacer for rear diff
mk2 or mk3 astra h/b rear shocks are a cheap longer shock for rear of the vits
Post by donkeychomp » Tue Apr 24, 2012 11:25 pm
Did a bit of checking and Grand Vitara springs apparently give a 1.5" lift. Might try that.
vitara_mad
Post by vitara_mad » Wed Apr 25, 2012 4:32 pm
donkeychomp wrote:Did a bit of checking and Grand Vitara springs apparently give a 1.5" lift. Might try that.
yes they do :doublethumbs:
