battery fixing
battery fixing
Battery fixing....anyone know how the battery should be fixed down....mine isn't and it failed the mot because of it !
- 1066 Boy
Re: battery fixing
Mine is held down with a small ratchet strap, went through last mot like it.
I Know how to work it. Not, how it works...............
believe me, there is a difference!!!
Re: battery fixing
As long as it's fixed down they are normally happy.
Here is a pic of the SJ fixings.
A kit from halfrauds would do the job, but one side may need shortening and the end bending back ?
http://www.halfords.com/motoring/bulbs- ... tery-clamp
A bit of flat bar with a couple of holes and some threaded rod from the DIY shop would do it if the filler plugs are flush with the top.
- www.suzuki-cat.ru.gif (34.38 KiB) Viewed 7841 times
Re: battery fixing
nice one thanks
Re: battery fixing
Ive got cable ties on mine
Re: battery fixing
not sure it would pas an MOT like that !
Re: battery fixing
Depends on how nice the MOT tester is
