Aftermarket steering wheel
- donkeychomp
- sidsuzuki2346
- Ladaman
- Suzuki Guru
Re: Aftermarket steering wheel
Have you tried finding an Ignis wheel? Mine is from an Ignis Sport and it bolted straight on. Much nicer than standard, a bit smaller and thicker.
I'm using Vitara wheel on my samurai, much more comfy wheel to use and straight fit.
- donkeychomp
Old Vits and SJ's share a lot of parts...the boss is one. If for some weird reason it doesn't fit (it will) you can always send it back.
I would also go for a steering wheel from another Suzuki model, should cost less than £30 too.
- sidsuzuki2346
- sidsuzuki2346
Fitted
- DSCN4329.JPG (64.31 KiB) Viewed 7705 times
