Throttle position sensor, Where to buy cheaper??
villagehoppa
Post by villagehoppa » Tue Jan 24, 2017 1:02 pm
Hi All,
I need to get a throttle position sensor for my 95 1.3 Sj, most other makes are around the £30 mark but could only find a couple for the SJ for over £100!!!?? Any one know why and where else I get a cheaper one!!!? many thanks... :er:
Re: Throttle position sensor, Where to buy cheaper??
Post by ROBBIE » Tue Jan 24, 2017 1:15 pm
Have you tried a motor factors? My local, gone now :cry: , used to try loads of suppliers to get me a good deal
zook123
Post by zook123 » Tue Jan 24, 2017 1:27 pm
Send me in a PM your reg plate and I'll do some digging :)
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
zook123
Post by zook123 » Tue Jan 24, 2017 1:57 pm
Cheers, my system didn't find anything, but I did find this..
http://www.ebay.co.uk/itm/SUZUKI-SWIFT- ... SwB09YSf9c
If they confirm that it has the TPS still on it, which it looks like it does, then that would fit!
villagehoppa
Post by villagehoppa » Tue Jan 24, 2017 7:23 pm
Fantastic, thanks for that, got a good motor factors round here actually so I might see if they can get me a new one cheaper, failing that, the Swift It will be... :salute: Thanks all...
Post by twiss » Wed Jan 25, 2017 6:51 am
The only for the injection Maruti Gypsy might be the same. I can probably get those. Has it got a part/code number on it?
villagehoppa
Post by villagehoppa » Wed Jan 25, 2017 8:34 pm
Thanks for that, I'll get it off this weekend and have a look for the part number.. :thumbup:
Rhinoman
Post by Rhinoman » Tue Feb 07, 2017 9:55 pm
Have you confirmed that it is faulty?
villagehoppa
Post by villagehoppa » Thu Feb 09, 2017 10:08 am
I've put the fuse in to see if there are any codes but they are all fine, there is no code, just the all clear code!?! Think I'll have to check all the hoses and see if there's a leak to why it runs so fast on start up from cold!! The plot thickens....
