Longer front struts
Longer front struts
So I’ve done A 3 inch lift on my vit And I’ve still got a standard front struts with spacers and was wondering if anyone knew anything longer to fit on the front to use the full travel of the updated spring and get rid of the spacers
- Rabid Rhino
Re: Longer front struts
Leda Suspension did mine... adjustable, rebuildable & any length.... about 100 per corner
Yer would rather something a bit cheaper lol bet there good thow looking on there website
- Rabid Rhino
You don't have to go for the adjustable so that'll be cheaper but the rebuildable could save you money in the long run.
Rear: you could use any old shocks
Front: your limited by the strut design. Maybe someone here can help you with part numbers of slightly longer units.
