New member first post
mustgetabiggershed
Post by mustgetabiggershed » Mon Apr 12, 2021 10:52 am
Hi
First post from me as a new member
Have had my SJ410Q since 1988
When I bought it was 6 months old
Used it regularly up to 2000
When I'm sad to say it was put it the garage and not touched until now
Having retired recently with more time to play
and get it going once more
So any advice would about where to start would be fantastic
I have drained and flushed the radiator
Going for the oil next
Have added a couple for photos of the poor old girl
Squiz
RichyP
Re: New member first post
Post by RichyP » Mon Apr 12, 2021 11:08 am
Welcome to the forum, plenty of SJ owners on here definitely in the right place. Soon be up and running again!
Larry
Post by Larry » Mon Apr 12, 2021 1:53 pm
Welcome!
Amazing that you've had it since almost new, well done for holding on to it, I bet there are so many people who would have sold it and lived to regret!
Guess you will need a new battery for starters or at least jump leads to turn it over.
Any fuel that's in there will be junk. You'll need to drain the tank and probably clean the carb as any fuel in there will probably have evaporated and left gunk behind.
Check you have a spark and with fresh fuel try and turn her over.
Although, once you have proved it runs it wouldn't be a bad idea to replace the cam belt and the water pump.
Post by Jordi » Mon Apr 12, 2021 6:50 pm
Welcome to SCUK.
Awesome that you have had since almost new.
Main advice after its been sat so long. Make sure the engine isn’t seized.
Turn it over by hand. Rocker cover off and drizzle oil over. Plugs out and a squirt of oil into the pots and turn it over by hand.
mustgetabiggershed
Post by mustgetabiggershed » Mon Apr 19, 2021 9:37 am
Hi Mate
Sorry only just got back to you
Thanks for the help
Just drained the oil out A lovely black colour as I expected
as for turning it over by hand
sorry to sound dumb but
Am I right in thinking best place to do this is end of the crank shaft pulley bolt in a clockwise direction
thanks again
CrazyCEO
Post by CrazyCEO » Sat May 01, 2021 1:06 pm
Wow well done for keeping hold of it. I stupidly got rid of my 1984 SJ410 in 1996 for a new Samurai and regretted it from day one. Good look with getting it back on the road.
sunil808
Post by sunil808 » Wed May 19, 2021 2:34 pm
hello everyone,
my name is sunil paul from india routing numbers tutuapp
