Post by ScottieJ » Tue Jan 17, 2023 9:26 pm
Really enjoying this build! Can’t wait to see it progress some more.
I was planning on doing a similar rear end on my new build so it’s awesome to see it on someone else’s truck.
d_r_1989
Post by d_r_1989 » Thu Jan 19, 2023 11:01 pm
Thanks Scottie. Hopefully make some more progress this weekend. Looking forward to getting it home so I can work on it at my leisure.
What was you planning on doing for the roof out of curiosity
Post by ScottieJ » Sat Jan 21, 2023 4:17 pm
The plan was to do the back end of the LJ270 like this so it won’t really have a roof….just a bit of aluminium to meet comp regs :lol:
I’m presuming you are going to run into issues with a roof and the cage B hoop hence the question? You could cut strategically placed holes with a slit into the soft top and then seal with a flap of rubber (or wetsuit material) sewn in and some Velcro flaps.
d_r_1989
Post by d_r_1989 » Sat Jan 21, 2023 7:26 pm
Well as a quick fix I bought a new roof from India that is a soft top but changes it into a pick up effectively. That will work how it is now but ideally I'd like to have a full roof in the end.
I just like to hear others ideas etc just like you have given! Always good to brainstorm.
d_r_1989
Post by d_r_1989 » Sat Jan 21, 2023 7:32 pm
Braved the cold today and got a few more hours in.
Welded some tabs onto the chassis and made the bottom radiator bracket, I folded some 3mm steel and fit some oe land rover rubber mounts for the 200tdi radiator.
Post by Rankine » Mon Jan 30, 2023 8:55 pm
It'll be driving in no time. Like the rad size my mate did a xud swap and struggled for right rad. Think he ended with something wider. But that looks perfect for the job
d_r_1989
Post by d_r_1989 » Fri Feb 10, 2023 11:08 am
Radiator and fan now mounted finally, made a little bracket that holds the top of the rad straight and the slimline fan.
Started to cut the front arches out to give clearance for the extra wheelbase on bump.
Just waiting on James to finish the rear cage so I can carry on, it's ready to run and drive when I put some fuel in.
The door was on just to check everything lines up, which it does
timwilks13
SCUK Website Padawan
Post by timwilks13 » Sat Feb 11, 2023 2:52 am
So put some fuel in and run and drive it then :guns:
Looking really good, keep us posted with progress!
Post by mike harris » Sat Feb 11, 2023 2:34 pm
Looks really cool man !
d_r_1989
Post by d_r_1989 » Sat Feb 11, 2023 5:05 pm
I'm holding off, as soon as James finishes the rear I can paint it then bolt the fuel tank in for final time. It's hard resisting though!
