1991 Santana Samurai
tomcat
Re: 1991 Santana Samurai
Post by tomcat » Mon Mar 25, 2024 1:40 pm
ScottieJ wrote:
Mon Mar 25, 2024 11:55 am
tomcat wrote:
Sun Mar 24, 2024 1:49 pm
I am examining power steering in great detail now. Have collected some parts together. Fixing bracket to engine block is not correct.
Sorry seems like I might have misled you on the Jimny G13 bracket. I have previously been told they fit but it looks like they added an extra mounting position on the Jimny G13 block, I always bin the 1.3 for a 1.6 so have never noticed that.
The vitara g16 brackets fit but the clearance to the chassis rail is tight. There are kits available from HM4x4 that come with an aftermarket mount and the crank pulley to match.
Your comments noted. Thank you. Will look at HM4x4 site and see what they offer.
tomcat
Post by tomcat » Tue Mar 26, 2024 8:41 am
Been doing some cleaning up, rustproofing of radiator supports.
Am able to get a clear view of area where power steering would go, whether hydraulic or electric system.
Located a PDF tutorial using a Toyota Yaris electric system to a RHD SJ413. From SJ 4x4 Africa.
Tried to scan a page onto here but was unable to.
Anybody interested in this, message me with an email address and I will send the PDF to you.
tomcat
Post by tomcat » Tue Mar 26, 2024 10:29 am
Some paint on the radiator supports.
tomcat
Post by tomcat » Tue Mar 26, 2024 10:37 am
View onto steering box area.
Alternator wiring will require modification as have upgraded alternator spec:
View onto power steering bracket area.
PO altered wiring to oil pressure switch. Not very happy with it.
tomcat
Post by tomcat » Thu Mar 28, 2024 5:18 pm
My research into power steering led me to look at the "electric hydraulic" system fitted to various models of Volvo.
Video on Youtube of one fitted to a LHD Samurai.
What else does one do when it is pouring with rain!!
Interesting set up that I shall look at further and report back.
Post by ScottieJ » Thu Mar 28, 2024 7:28 pm
My experience of the electric hydraulic pumps when combined with the Jimny steering box is that it’s usually quite rubbish and the steering is still heavy, people used to use the PSA units.
I would just fit a suzuki based, engine driven pump using a kit. It’s a simple and reliable set up that’s proven to work.
tomcat
Post by tomcat » Fri Mar 29, 2024 10:02 am
As ever ScottieJ your comments noted and appreciated. Thanks.
tomcat
Post by tomcat » Sat Mar 30, 2024 10:40 am
My woes regarding finding a fixing bracket for a power steering pump continues!!
Am now thinking of measuring up and having one fabricated.
Fixing arrangement as shown in picture.
tomcat
Post by tomcat » Sat Mar 30, 2024 10:49 am
Moving on to alternator upgrade I plan.
As expected, distance between fixing lugs on existing bracket will clash with fittings on purchased alternator.
We are investigating solutions.
Edit note: Inside dimension between fixing lugs on new alternator is 68mm
Outside dimension on original bracket fixing lugs is 77mm. :thumbdown:
Post by ScottieJ » Sun Mar 31, 2024 12:04 am
https://www.hm4x4.com/en/suzuki-samurai ... nting-pump
