Hey
- Edweird
Re: Hey
I can only think a few ways to -possibly- come up with the capacity. First would be to have it officially measured, with could be done via. the bore and/or crank distance, or you sit it next to another SJ and compare noises/engine response.....Though that's a bit hit 'n' miss. Fuel economy is a possible, though I think that that's dubious again.
You could examine the t-box ratio, but if the gearbox is wrong the t-box might be too.
Hand brake? Rear shaft or rear drums?
Do you have a servo?
Front ARB?
But if the vehicle has been fiddled these might not be valid either.
Nice 'n' vague. Perfect.
Front ARB?
Re: Hey
Nice colour! they're 410 front wings, there's no side repeaters, its just had Sammy badges put where the side repeaters go. Can we have a photo of the engine bay and the front of the chassis please. Sounds like someone might've just fitted some Sammy number plates to a 410 The vin plate should be in the drivers side footwell, between the speaker hole and door. I would check all the details match your v5?
Online
- Tramp
Re: Hey
not just the number plates.... they have been clever about it! they moved the sammy badges to the indicator holes as not to arouse suspicion!!!!!ScottieJ wrote: Sounds like someone might've just fitted some Sammy number plates to a 410
Re: Hey
Edweird wrote:I can only think a few ways to -possibly- come up with the capacity. First would be to have it officially measured, with could be done via. the bore and/or crank distance, or you sit it next to another SJ and compare noises/engine response.....Though that's a bit hit 'n' miss. Fuel economy is a possible, though I think that that's dubious again.
Front ARB?
Or just look on the side of the bell housing to see what it says ?
Its easy to tell a 1.0 from a 1.3.
This is a 1.3
This is 1.0
Im almost 100% sure that there is no such this as a 4spd 1.3.
