rear disk pads
urbanzook
rear disk pads
Post by urbanzook » Thu Oct 09, 2008 9:59 pm
i put new pads an disks all round my sj an the rears have worn down 2 metal an the fronts look new.???
ain't it meant to be the front you use the most??????
what could cause this?
muddy kev
Re: rear disk pads
Post by muddy kev » Thu Oct 09, 2008 10:12 pm
are the rear pads all worn down, ie both pads on each side or is it just 1 pad per side?
zook123
Re: rear disk pads
Post by zook123 » Fri Oct 10, 2008 10:01 am
sounds like the brakes are running a bit lame!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
urbanzook
Re: rear disk pads
Post by urbanzook » Fri Oct 10, 2008 5:34 pm
both pads on one side worn.
not checked the othere side guna 2 night so ill let ya no
but looks ok.
urbanzook
Re: rear disk pads
Post by urbanzook » Fri Oct 10, 2008 7:13 pm
ok just checked all 4 sets there was one pad with excessive wear.
passanger rear inner pad.
did notice that all 4 rear pads where worn wonky.
muddy kev
Re: rear disk pads
Post by muddy kev » Fri Oct 10, 2008 7:42 pm
blimey they are worn! how long did it take 2 get them that low? they all seem very low and if the fronts are still ok must be something holding them on. are the dics blue'd ? would be if calipers are sticking causing over heating, if not try the load compensator may be your doing most of your braking on the rears. hope this helps.
urbanzook
Re: rear disk pads
Post by urbanzook » Sat Oct 11, 2008 10:12 am
i changed them all six months ago the frunts look new an the backs are as you see them.
there is no blueing off the disk.
i think the hangers are sitting wonky an the pads are not sitting right.
wearing them unevenly fast.
k30rdj
Re: rear disk pads
Post by k30rdj » Sat Oct 11, 2008 2:53 pm
defo sticking on think you need a service kit or 2
urbanzook
Re: rear disk pads
Post by urbanzook » Sat Oct 11, 2008 5:17 pm
i must add i also had all 4 callipers re-bilt
Re: rear disk pads
Post by ScottieJ » Mon Oct 13, 2008 12:28 pm
how have you done your rear disk conversion, from the way the pads are worn it almost looks like the callipers are not sitting square to the disks?
