parrots trak
- Can I have a tow
Re: parrots trak
sorted my fog lights out today,what a pain that was.done my pump timing but its still down on power.
- Can I have a tow
Re: parrots trak
i give the truck the once over to see what it neede for the mot,i new it needed 2 track rod ends as the rubbers have split and a new steering idler as the bolt has seized in the bush.
it also needs a rear uj as it has a bit of play in
it wont stick out this far but give you the idea of how it will be
- Can I have a tow
Re: parrots trak
i took a half day today and got the rest of the week off and monday so i bypast's the tank.fuel lines and filter and it went better,not great but better.
i also got some new ujs,cost £55.94 for 2 plus i order'd new track rod end's,pit man arm and another steering idler from milner's ,that lot come to £191.70.
- Can I have a tow
Re: parrots trak
got my fuel filler cap fitted,cut down the side,fitted a end to my exhaust and took my prop off to have the ujs replace'd by a mate of mine.
- Can I have a tow
Re: parrots trak
got a bit done today,done the other side light,filled the rear door handle over and any little holes in the door,fitted 2 brackets to the front wings to hold them on better,had the uj's done(mate said they were a nightmare todo),fitted the new rad fan.
the parts come from milners come today so i fitted them,well the trackrod ends and the pitman arm but not the steering idler(see vid later)
