Calmini Shackle Reverse
Re: Calmini Shackle Reverse
Thats what im thinking of as mine with add a leafs just does not flex at all, going to try longer shocks and lines first see how we go then if not its the old shackle reversal we think
With SPOA do you need to do anything other than the welding & brake lines?twiss wrote:If you want mega-flex spoa and single leaf springs work really well.
My mate had that combination on that SJ that joined here a while ago. The one that was blue and is now black...
Got super flex out of it! We could flex the truck by hand, to the point of tipping it over lol
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
My add a leaf was really really hard, but I've bashed it around enough to soften it up now
The added leafs will now pretty much bend to being flat.
- Tramp
charger wrote:With SPOA do you need to do anything other than the welding & brake lines?twiss wrote:If you want mega-flex spoa and single leaf springs work really well.
some form of steering, usually its done by a z link bar, but merc hi steer is the best way to sort it
There is a full calmini 5" lift it in the difflock classifieds for £400 http://forum.difflock.com/ads_item.php?id=14228" onclick="window.open(this.href);return false;
Great find I'm trying to keep things as cheap a possible though. The guy I bought the SJ off is a mechanic so I might see if he can do the leaf over axel. Failing that a freind of mine is coming over from the USA might see if he can bring me the Calmini kit. Or there is always the shackle son fleabay for £25.ScottieJ wrote:There is a full calmini 5" lift it in the difflock classifieds for £400 http://forum.difflock.com/ads_item.php?id=14228" onclick="window.open(this.href);return false;
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Looking for a shackle reverse kit, anywhere in the UK that sells them?
- Tramp
I got mine from l.a.supertrux.com they don't list them any more but it may be worth giving them a ring
specialist leisurexiztrn wrote:Looking for a shackle reverse kit, anywhere in the UK that sells them?
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
