1.6 head on 1.3 block??
khem
Post by khem » Sun Oct 19, 2008 6:52 pm
hi all!!..am trying to juice max power from my sj 1300cc engine....for the challenge of jus doing so i guess:)...so i don't want the 1600cc engine...i'm wondering if it's possible top bolt on the 1600 head(8 or 16 valve) on the 1300 block, and to what extent would that improve performance...looking forward to your replys!!
urbanzook
Re: 1.6 head on 1.3 block??
Post by urbanzook » Tue Oct 21, 2008 10:17 am
the 1.6 head is the same as the 1.3 the dif with the engen is the bottom end larger pistons. Some 1.6 come with a pump on the head an some have electric one in the tank. If your guna change the head you may as well do the hole jump. Or change your carb. An in the world off mud speed ant any think is all about the talk.
khem
Post by khem » Fri Nov 14, 2008 10:31 pm
ok....thanxx..
do u know if the uel injected sidekick head gasket can fit on my sammy?...plzz reply asap...i've blown my head gasket and would like top replace asap....thanx alot
