Post
by Kirkynut » Sat Jan 17, 2009 1:10 pm
Hi there,
I had the same problem but with my standard tea candle like bulbs and don't think it's because you are overloading it.
The problem I had was a bad connection from the pin in this plug to the fuse board.
As bottom plug to the fuse board is only an earth, and therefore it doesn't matter which hole you place the pin it, it still only goes to earth, you can carefully pull the pin out of the plug and place it in one of the spare holes, ensuring it's put back in firmly, and it will make a good connection in it's new home and stop all the worries.
Have a look, give it a go and it will solve it nice and quickly.
Rob
