Uk samurai wiring diagram
iwbunting1962
Post by iwbunting1962 » Fri Oct 29, 2010 8:02 pm
Hi guys
Has anyone got a copy of a uk Sammy wiring diagram ?
Or are the us or canadian ones close enough ?
Cheers.
Ian
Re: Uk samurai wiring diagram
Post by ScottieJ » Fri Oct 29, 2010 8:05 pm
What you need to know is whether your SJ is made in Japan or spain as they use some different colours.
If it's Jap then use the wiring diagram in the stickies at the top of the electrical section.
If it's spanish i'll try and find you one :mrgreen: I think there is only small differences though like two yellow and white wires on the alternator instead of one and maybe different wiring on the lights???
Post by Tramp » Sat Oct 30, 2010 12:23 pm
to tell the difference between the spanish and the jap sj's look at the vin plate in the foot well, japanese vin number starts JSA wheras the spanish is VSE.... to be honest I don't think spanish ones went to the America, I think they were all japanese (they only made the spanish factory because if they wanted to sell in europe a percentage of the cars had to be produced here)
Luke
iwbunting1962
Post by iwbunting1962 » Sat Oct 30, 2010 7:51 pm
Thanks Scottiej
Re - White/yellow on alternator...yes,i traced 2 of em back to the alternator .....
Not sure if ours is spanish or jap as we have no vin plate but i have found that on yank or canadian looms the 2 white/yellows on the alternator have been replaced by 1 but go into 2 internally linked ones in the loom.
I am in the process of making a new loom for a 1.6 vitara,su hi44 combo ... ignition and alternator with wipe/wash and heater.New switch/control panel from demon tweeks and naster cuttout with overrun relay fitted.
bourneyo
Post by bourneyo » Wed Nov 10, 2010 12:35 am
Another way to tell if your truck is spanish or jap, spanish have square indicator/light stalks, a cronic rust problem and plenty of electrical gremlins :twisted: , japs have round indicator stalks! hope that helps and it not to late.
Dan 8-)
Henry
Post by Henry » Wed Nov 10, 2010 10:35 pm
HI
I went over to Ians the other night, he has a fair wiring project on his hands! Found the vin plate, it had been moved to the engine bay. Started with VSE.
I do belive that this is spanish.
Post by twiss » Wed Nov 10, 2010 11:33 pm
I believe you're right :)
iwbunting1962
Post by iwbunting1962 » Sun Nov 14, 2010 8:14 pm
Hi Henry and all
Stripped all the old harness out today.
Got it running again with 5 wire loom and no switches
Started rewiring centre console with new fusebox and satrter panel from demon tweeks.
Keeping wash wipe on stalk and heater/blower controls.Fitting and electric radiator fan on a switch
Just need to sort charging circuit and away we go
Thanks all for input
Ian
KennyRogers
Banned
Banned
Post by KennyRogers » Wed Jan 11, 2012 8:20 am
I have a new wiring harness and Im having a problem connecting it to the other wiring kits. A little help will do.
Post by ScottieJ » Wed Jan 11, 2012 9:21 am
KennyRogers wrote:I have a new wiring harness and Im having a problem connecting it to the other wiring kits. A little help will do.
Post some pics of where you are having problems and Im sure we'll be able to help
