Newtomud's Newtobuild
Newtomud
Re: Newtomud's Newtobuild
Post by Newtomud » Thu Apr 19, 2012 6:36 pm
Keeping it Suzuki :thumbup: and looking for something different..
Fuel tank 001.JPG (718.36 KiB) Viewed 7274 times
Post by Edweird » Thu Apr 19, 2012 7:47 pm
What is that? :S
Post by turbo-tom » Thu Apr 19, 2012 8:23 pm
old "skool" petrol tank by looks? :smokin:
Post by ROBBIE » Fri Apr 20, 2012 9:41 am
outboard motor tank?
Newtomud
Post by Newtomud » Fri Apr 20, 2012 6:36 pm
ROBBIE wrote:outboard motor tank?
Top marks Robbie.. 5.3 gallons genuine Suzuki.. Brand new "old stock".. Comes with filler,breather and fuel gauge.. Has the handles on the side to strap it down with. Just need to work out what to do about the return fuel feed.
I'm quite pleased with it cause it's a bit different.
Post by ROBBIE » Fri Apr 20, 2012 6:49 pm
used to have 1 and the motor it was connected too
Post by turbo-tom » Fri Apr 20, 2012 7:04 pm
regard the fuel return pipe , you can either block it off i wouldnt exactly recomend it though , or apparently you can put a t peice in it but im not sure how that word work :oops: :lol:
Newtomud
Post by Newtomud » Fri Apr 20, 2012 7:13 pm
I'm new to this but thought that maybe a "T" back into the feed fuel pipe would just suck the petrol back towards the carb?
Post by turbo-tom » Fri Apr 20, 2012 7:30 pm
in a way it probably would but if petrol is going back up to the carb it would go into the engine and burn etc , but it might flood the engine im not 100% sure sorry!
Newtomud
Post by Newtomud » Tue Jan 22, 2013 8:20 pm
Made a new rear bumper from 100x100x5mm box section with inset 90 lights..
Only had an electric drill and a metal file.. so took some time.
