Hey Guys.. not a Suzuki owner.. but hopefully will soon be.
S1MON
Re: Hey Guys.. not a Suzuki owner.. but hopefully will soon
Post by S1MON » Sat May 19, 2012 10:08 am
The turret inside the car has been modified so my mate seems to think its a different box. I'm not too sure, i will take some photos later of the engine and underside and post them here :) Thanks for your help.
Post by dan_2k_uk » Sat May 19, 2012 12:15 pm
If thats your workshop I'm jealous!
Post by Tramp » Sat May 19, 2012 1:16 pm
Its a nice looking truck, its just a shame about that bonnet scoop!
S1MON
Post by S1MON » Sat May 19, 2012 8:38 pm
dan_2k_uk wrote:If thats your workshop I'm jealous!
Its where I work but pretty much can use it whenever I want, evenings and weekends with in reason. :)
S1MON
Tramp wrote:Its a nice looking truck, its just a shame about that bonnet scoop!
Yeah is a bit ugly, not sure what else I can do with it though? Going to tidy up the welding on it and round it off a bit sometime.
S1MON
Post by S1MON » Sat May 19, 2012 8:42 pm
Washed it off this morning.
Gave the engine bay a bit of a clean as had a very bad oil leak, also replaced the rocker cover gasket today aswell.
Fixed the running issue.. the choke had too much play in the cable/pin and it was constantly fully open thats why it was running shit. So had to add a nut on the end of the pin to hold it closed.. Bit of a bodge but will be ok till i get a new carb.
Shouldn't the prop be running straight?
My mates mint SJ and mine.
S1MON
Post by S1MON » Sun May 20, 2012 2:32 am
opps..
Post by ScottieJ » Sun May 20, 2012 10:48 am
Well you know your mate said that he thinks it uas a different gearbox, it does ;)
In fact that is a complete vitara transmission, transferbox n all! Hence why the rear prop is at such and angle.
The bad thing with that set up is that it won't be as easy to lower the gearing if you want to fit large tyres, however it does mean that you could easily run yotas hi lux axles with the centred rear diff.
S1MON
Post by S1MON » Sun May 20, 2012 12:01 pm
So is there a way to lower the gearing? And the tyres are pretty big. It doesn't have much grunt low down and you really have to wind it up to get going on the road.
Post by dan_2k_uk » Sun May 20, 2012 12:30 pm
You can swap the gears in the diffs for some from a vitara front diff if that hasnt been done already.
Will try find a link and stick it here.
http://forum.suzukiclubuk.co.uk/vi ... 12/t,2801/
Dan
