New member
New member
Hi I'm Chris just got a Suzuki sj410
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
- Edweird
Re: New member
Welcome to the crew lad.
Re: New member
I,ve just brought me first Sj but can't find vin due to replating ,done hpi on it alls good have no paperwork at all just the reg number and engine number is there any way I can get vin using that ? Help :(
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: New member
to the forum matey
The Vin should stamped on the outside of the right chassis rail under the front wheel arch. it'll probably be quite well hidden under the paint or a coating of underseal usually though
by replating do you mean it doesn't have th original plate? The vin plate is usually rivited just inside the drivers door at the front between the speaker and the door.
Re: New member
Welcome to the club mate.
Get some photos up, everybody loves photos!
Dan
Dan
Re: New member
iPad won't up load photo but if someone emails me I,ll sent one to put up (princer132@aol.com).Cant find one on chassis and had new footwells so no plate inside either.
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: New member
Cheers guys just got grinder on chassis to clear layers and layers of undersell and found it
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: New member
Nice one it's always there and 9/10 times hiddenCrisdolf wrote:Cheers guys just got grinder on chassis to clear layers and layers of undersell and found it
drop an email to admin@suzukiclubuk.co.uk with a pic
Re: New member
Thanks for that she's not bad little bit of work and it will be good as new
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
