Drag link and Anti Roll Bar
Gardiner
Post by Gardiner » Tue Oct 23, 2012 9:26 pm
2 Questions
First just noticed there is No Anti Roll Bar on my 1986 SJ I have bought will this have major problems I am planning to use 50% on road and the rest of the time off road.
Second My sreeing drag link has a split rubber on solid end the joint feels fine can you get new rubbers or do you have to replace whole arm
Thanks In Advance
Re: Drag link and Anti Roll Bar
Post by ScottieJ » Tue Oct 23, 2012 9:35 pm
I've never had an anti roll bar and don't feel the need for one really, my sj is a daily drive.
Only laters sjs had them fitted. I don't hang about in my sj either.
You should be able to replace the rubber? Not sure where you would by the rubber separate either??
Post by Darrell » Tue Oct 23, 2012 9:56 pm
Had a "Google" and this company says number 1 fits the SJ !!
http://www.balljointboots.co.uk/
tie rod etc.gif (34.92 KiB) Viewed 5668 times
Post by Tramp » Wed Oct 24, 2012 9:23 am
If its 1986 chances are that from standard it never had an anti roll bar fitted, the way to tell is by looking at your spring plates(what the u bolts attach to) on the wheel side, there will be a threaded sleeve (if it ever had an anti roll bar fitted)
