Starters for sj 1.6 conversion
Re: Alternative starter for sj 1.6 conversion
Post by twiss » Wed Dec 15, 2010 10:31 am
I actually broke both diffs, my alternator, and my starter :roll: :cry:
All fixed now, ready for another trip up to wycombe!!!
Nasher
Post by Nasher » Fri Dec 17, 2010 1:36 pm
will the vitara v6 starter motor fit? it has 9 teeth and the same fitting by the looks of it as the d6ra62
Post by twiss » Fri Dec 17, 2010 1:55 pm
Not entirely sure...
to be honest, I'm going to send a picture of my actual starter housing
(the one I think is a D6RA12) to Valeo and ask them to identify it.
When I got the starter it had the D6RA12 sticker on the motor...
and as far as I can remember I had to cut the rivets off to split the thing.
So it should be the correct model number, unless someone has swapped the motor, and then re-riveted it back together
I just want to double check before someone buys a D6RA12
Oh yeah, re-read the original post, I've altered it cos it was wrong :oops:
Post by twiss » Fri Dec 17, 2010 4:54 pm
Some additional info from Valeo's online parts catalogue
General:
EAN 3276424333216
Status Normal
Packing Unit 1
Trade Numbers 183199, 187332, D6RA12, D6RA72, D6RA721
Supersedes 432593
Certificate Remanufactured Part
Criteria:
Voltage [V] 12
Rated Power [kW] 1,2
Number of Teeth 9
Number of Holes 3
Position / Degree L 58
Rotation Direction Clockwise rotation
Clamp NON
CITRO - XM (Y3) - 3.0 V6
05.89-06.94 11.89- 123 167
2963cc
CITRO - XM (Y3) - 3.0 V6 24V
07.90-06.94 - 147 200
2963cc
05.89-05.94 - 123 167
2975cc
CITRO - XM Estate (Y3) - 3.0 V6
11.91-04.94 - 123 167
2963cc
CITRO - XM (Y4) - 3.0 V6
05.94-10.00 07.94-05.99 123 167
2963cc
CITRO - XM (Y4) - 3.0 V6 24V
05.94-10.00 07.94-06.97 147 200
2963cc
CITRO - XM Estate (Y4) - 3.0 V6
2963cc
PEUGE - 207 SW (WK_) - 1.6 HDi
06.07- 10.07- 80 109
1560cc
PEUGE - 605 (6B) - 3.0
10.89-09.99 -05.99 123 167
2963cc
PEUGE - 605 (6B) - 3.0 SV 24
08.89-09.99 10.89-06.97 147 200
2963cc
08.89-06.94 09.90- 123 167
2975cc
lightning
Post by lightning » Thu Mar 03, 2011 3:14 pm
HELP i need a starter
I got 1 from Wood Auto as you suggested
IT WILL NOT FIT :argh:
i have done the 1.6 conversion with 1.3 gear box
Need help at my wits end :bawling: :bawling:
Mark
chris71920
Post by chris71920 » Fri Jun 29, 2012 10:58 pm
Any light shed on this?
ianedwards
Post by ianedwards » Sat Jun 30, 2012 1:58 pm
the starter on mine fits ok, it was on there when i bpought it. im going up there after, shall i get a pic and the numbers ect off it, dunno if it could you guys?
Ian
Ian. :)
ianedwards
Post by ianedwards » Sun Jul 01, 2012 10:58 am
ok, there are no numbers on it, just a mitsubushi logo. lable must have fallen off at some point.
still got a pic tho if u want it.
Ian
Ian. :)
chris71920
Post by chris71920 » Fri Aug 31, 2012 10:11 pm
Thinking of buying a D6RA-12 as I know the motor and solenoid will be good and I can just change the housing from one of my D6RA-13's? The end looks exactly the same as far as bolts and positions of all holes etc
And this should work fine?
dannytrigger
Post by dannytrigger » Tue Feb 12, 2013 4:56 pm
Can any one confirm this will bolt straight on befor i purchase it?
1998 VAUXHALL CORSA 1.4 12V STARTER MOTOR 30F80341FPN2 90341777 D6RA62
cheers
