Wheel hub empty
Re: Wheel hub empty
it must have brakes and handbrake just for scrutineering for trialing...plus its always nice to stop before hitting into a bit tree....purely speaking from experience ;-)
Re: Wheel hub empty
Ahhh I see, didn't realise it was going to be trailed. Figured it was just a pay and play rag about motor.
Re: Wheel hub empty
What's the spec of the vehicle, year . 413 or samurai? Spanish or jap?
Re: Wheel hub empty
The cylinders on my 413 are different IE: one has fluid in/out, the other fluid in/bleed nipple.
Your also going to need a couple of self adjusters (part 19)
Here's a pic of mine
- DSCF6930.jpg (401.77 KiB) Viewed 6594 times
- rear brake .jpg (45.65 KiB) Viewed 6594 times
Re: Wheel hub empty
thank you very much, thats just what i was going to ask for...... ive bought all the bits, just waiting for the cylinder to arrive then i can start assemblty.,..that diagram will make my life a lot easier, much obliged
Re: Wheel hub empty
ok so ive just opened all the boxed.....and im still missing a piece :*-(
what is number 19 in the diagram please?
Re: Wheel hub empty
ok....just re - read your post.... self adjusters...lol
are these again specific to the model?
it's just a n/s i need as the o/s is in tact... does anyone happen to have one?
Re: Wheel hub empty
would you happen to have the nuts & bolts needed for the brake cylinder and shoes?
Re: Wheel hub empty
what are parts numbered 8 & 21 on the diagram plz and where can i get them?
Re: Wheel hub empty
21 is just a rubber bung to fill in a hole in the backing plate to stop crap getting in.
8 goes through the backing plate, then through the shoe and is held in by the number 9 clip.
