Bedford rascal rear srings go on with minimal hassel, altho you may need to fab up some new shackles, RUF (rears up front) is a lil more involved, but the aded advantage is you can make some missing link shackles, like the D-flex shackes, if you have seen them, so you get loads more front flex. you will need longer shocks for both, and to extend your front prop for RUF as well as longer brake lines. I have done this to my SJ although i haven't tested it out yet. if you do decide to do this i can go through it in abit more detail. I would avoid extended shackles as they do more damage than good.
Dan
