G16A engine conversion last snags
Re: G16A engine conversion last snags
A few pics I found
- engine.jpg (137.6 KiB) Viewed 7075 times
- carb_side.jpg (122.8 KiB) Viewed 7075 times
- carb.jpg (83.56 KiB) Viewed 7075 times
No idea why the last guy put the return to the carb but thats sorted now lol.
The main pick up is laying over the front and has a small electric inline fuel pump (which u cant see in the pic) Ive removed this hoping that the vacume pump on the engine will work? Unless the 410 have a fuel pump in the tank? Im not to sure?
Thx for the pics btw, great help
at the bottom and slightly to the right u see a brown plug. i have nouthing to go into this and the main loom wires have been cut. Any idea what it is and if i need it?Richie wrote:and again
Also right next to it (u cant see in the pic) are 2 plugs, again ive got nouthing to go onto them and have no idea what they are, any ideas? Thx
- DSCF3128.JPG (726.23 KiB) Viewed 7061 times
Fuel return via the carb is how it's originally plumbed, no idea why ??
- Vitara fuel pipes.jpg (209.92 KiB) Viewed 7060 times
Thats the idle up system. The SJ also has this system, it's fine to leave it off.
I can check the wires colours if you want to connect it.
- Idle up system.jpg (90.9 KiB) Viewed 7055 times
"Also right next to it (u cant see in the pic) are 2 plugs, again ive got nouthing to go onto them and have no idea what they are, any ideas? Thx"
In a word ----------
No
No
Cheers Darrell, we've been fitting my old 1.6 carb into my dads maruti and I couldn't for the life of me remember exactly how the fuel pipes were plumbed the other weekend and couldn't find any decent pictures or diagrams. It was ages ago that I took it off and its such an over complicated carb
Understatement! SU - fuel in, breather, overflow, vac advance. Most jap cars of the era ran very similar carbs Hyundai, subaru, daihatsu. They all die in the end. I've tried most in the past, they work for a bit then break. Even the manual choke ones.ScottieJ wrote: its such an over complicated carb
Vit carbs aren't quite so unreliable luckily.
I will take a pic of these plugs and show ya as they look alittle out of place, Thx for ur help so far. I will have anouther 3 hour play with it tomorow to see if i can get it going. Apart from a live wire hanging down near the starter not wanting to connect to anything and a dead starter motor its just about there
Btw anyone know if my vit carb has a manual choke? Cant seen to find anywhere to put the choke cable
