Wobble truck...
SJay
Wobble truck...
Post by SJay » Sun Apr 21, 2013 12:38 am
Not had my sj very long, it's a bit of a project I guess. Anyways when I picked it up the wind was horrendous on the motorway, probably the scariest driving experience I've ever had, really weird wobble that seems to be coming from the rear. Thought it just might be because of the off road tyres, I'm totally new to 4x4, so just put it down to the high winds.
Since then It's been happening when sharply turning, on bumpy roads and worse at 50mph+..
So tonight i checked it over, and one of the u bolts on the passenger side is missing.. Wow. Gonna sort that tomorrow and tighten every other bolt up, but anything else to check? I'm kinda supposed to be collecting and towing back a small boat this weekend.. A 600 mile round trip! Don't fancy it driving it like it is
ferris
Re: Wobble truck...
Post by ferris » Sun Apr 21, 2013 12:55 pm
Missing a u bolt :shock: , that sounds like your problem. I would also check for any play in the wheel bearings.
Re: Wobble truck...
Post by Jordi » Sun Apr 21, 2013 1:01 pm
Bearing, wheel nuts, drum nuts, prop shaft. Make sure all nuts are correctly torqued.
SJay
Re: Wobble truck...
Post by SJay » Sun Apr 21, 2013 2:01 pm
Cheers, yeh decided not to go now. Gonna get some new u bolts ordered, yeh one of the nuts is missing from one... :thumbdown: lol
Re: Wobble truck...
Post by Darrell » Sun Apr 21, 2013 2:23 pm
Dave at http://www.llama4x4.com/page5.htm has a good reputation :thumbup:
u bolts.png (183.62 KiB) Viewed 6120 times
Re: Wobble truck...
Post by Edweird » Sun Apr 21, 2013 4:10 pm
Darrell wrote:Dave at http://www.llama4x4.com/page5.htm has a good reputation :thumbup:
I got my U-bolts from there. Friendly bunch. Had them in the post right quick.
One thing I might point out which I rang back about and had explained to me:
If you get a full set of U-bolts, you should find that there are two of them that have a larger radius curve on them. These two bigger ones are for the front axle on the side nearest the diff.
Re: Wobble truck...
Post by andyrew » Sun Apr 21, 2013 11:18 pm
Most of the drum nuts ive worked on are usually knackered
For a couple of quid you can get a new set from muddyzook.com
steve greenc3
Re: Wobble truck...
Post by steve greenc3 » Mon Apr 22, 2013 9:52 pm
Check your kingpin bearings, these make an interesting drive when gone past there best!!
