should I remove these?
To get more upwards flex should I remove these brackets on the front springs or would they be to weak? They are the rear springs but fitted to the front.
- 20130521_110946.jpg (2.64 MiB) Viewed 3197 times
Re: should I remove these?
These brackets
- 20130521_110956.jpg (2.29 MiB) Viewed 3194 times
Yes you can remove them but you might get a bit more axle wrap, they shouldn't make any difference to up travel though as you should really set your bumpstops at the point the springs are flat to avoid over flexing them anyway.
Sry I ment down travel. Would that improve the articulation and safely let the wheel drop down further or over bend yhe springs?
