Astra shock part no.
- timwilks13
- SCUK Website Padawan
Just rang my local supplier for a quote for some mk4 astra front shocks, but they say they cant find the part without a registration number, distinctly unhelpful! Does anyone either a) have a part number for these, or b) own a mk4 astra (as a second car i hope!!) that they dont mind me giving the reg to get these ordered?
Re: Astra shock part no.
mk4 astra front shocks? most people use mk2 rears
Fairly sure these are the right ones.
http://forum.suzukiclubuk.co.uk/vi ... Kyb#p41868
The have eye at the bottom and pin on the top. Bolt straight on the front. Scotties modified them to fit the rear.
- timwilks13
I was reading through loads of these forums, which is why i wanted a quote for them and could have sworn someone said they were using mk4 fronts, my mistake! mk2 rears it is then!
Scottie is the part number 343047 on the link that Jordi gave for mk4 rears?
- Ladaman
- Suzuki Guru
These are the ones I used. Not sure of the MK now, but they fitted a treat on the rear with an angle iron bar at the top. I haven't fitted them to the front yet.
- image.jpg (582.75 KiB) Viewed 6174 times
- ektoz
i will go today and pick up 2 rear toyota rav4 shocks they are the same as mk2 (eye at the bottom and pin on the top) i put front and now i will do the scottie mod for the rear, if you want i will post some pictures for you the size exlacly
- ektoz
Mk2 Astra rears are 343mm (13.5") closed and 584(mm (23") open if I remember correctly
Travel 241mm (9.5")
Travel 241mm (9.5")
